Re: problem puch...
Joe Woods /
you can determine if the ignition is ok by using some Starter Fluid .. spray a bit into the carb or spark plug hole.. if it fires up, ignition is ok..
sure sounds like a fuel problem to me.. Check for a wet or dry plug tip condition after a failure to start..
