carburetor
Matt Delaman /
Hello I have an 01 tomos lx and when I go riding the carburetor slides right of the intake. Yes I know it sounds like a lose carburetor bolt but when I pull over it is as tight as it can be.so I don't know what it is so any ideas are useful.
Thank you,
Matt.
Re: carburetor
Maybe its the plastic spacer on the inside edge of the carb.
Re: carburetor
Sometimes you have to grind(Dremel disc) a LITTLE bigger gap where the bolt piches the aluminum over the plastic sleeve. Just fix it so it can tighten a little better. A little goes a long way here,though. don-ohio
