Re: Motobecane 50v not shifting
Dan Adams (50:1) /
your clutch is stuck, here is the shop manual http://mopedriders.org/article_view.php?faq=2&fldAuto=18
-you may be able to remove the belt, force the outside "sliding cheek" in, and put a bunch of grease on the metal balls
-you can remove the clutch cover with a ratchet set, and a piston stop. you may find that stuff in there has coroded, and stuck itself
-you may need to pull the clutch (tool available at moped warehouse)
god luck
