Re: Cable Question
Don Pflueger /
then they dont have a clue what they are doing. knarps are cble ends used to make custom cables or repairs. it is a small threaded barrel with a hole drilled thru the side and a tiny set screw at one end. you push the wire thru the hole then tighten the set screw down to clamp the wire. most expensive hybrid race bikes use these.
