Re: Cable Question
Don Pflueger /
its on a throttle? your probably best to buy a new cable. wal mart sells a bicycle tune up kit for $4.23 and it comes with 4 cables. if you use a delortto carb, a derailleur cable will work with just a small amount of grinding or filing. otherwise, throttle cables cost anywhere from $9-$14. but if you need a brake cable, the ones in the tune up kit will fit fine. or you can buy a thing called a knarp at any bicycle shop. its a replaceable cable end. but you need to know what style end you need first. the tune up kit has a variety of ends to fit every need.
