Re: Rusty chain
Elliot /
Today I had a lot of rust on my chain and I sprayed on a chain lube that is for O-rings.
Is it ok to use this O-ring chain lube or do I need something else?
Thanks for the suggestion about using a rotary tool with the wire wheel to get the rust off. That is what I will do and then re-appy the proper chain lubricant.
