Re: Rusty chain
See Ya Moped Army /
At a minimum, you've got to get that rust off. If the links are pitted from rust, then throw away the chain. If it's just surface rust, I use my wire wheel on my grinder to clean the rust off I then use a good quality motorcycle chain lube to lubricate it. Spraying lube over the rust is just a waste of time and will do little if anything.
