Minarelli Wiring
I have a Minarelli V1 engine that I'm trying to wire up.......looking at the wiring diagram on Mopedriders.org and my question concerns wirirng the coil. It shows the blue wire running to the points and primary ignition coil....is this the wire that I run to the "high tension" coil, or is it the red wire ???? It's just a little confusing. Thanks in advance.
Doug
