help with leaky petcock
Lee Todo /
so my petcock leaks. and the gas appears to be comming from the area around the lever, not out of the gas line connection. i took the petcock apart and it looks like a rubber o ring is designed to keep the gas from getting to the lever area. i guess the o ring on my petcock is not working. has anyone else had a similar problem? is the answer as simple as a new o ring?
thanks for the input
