Re: Honda "Express"ing difficulty...
Joe Woods /
_it’ll rev itself up a bit high all by itself_
_it keeps going when I let off the throttle_
not a lot to say about it .. something or other about the carb seems to need attention.. idle air flow or choke or float level or something aint right.
Did you measure the new piston and the bore? Normally, the bore should be about 0.002 larger in diameter than the widest part of the piston skirt.. near the very bottom of the skirt, crosswise from the trunnion pin.
Good to hear there's no evidence of seizure. Gap the rings to be sure they are not binding when the engine gets hot.. A ring's end gap when it's slipped into the top of the bore should be near 0.008 inch, at least. Too little gap can make them bind and cause lots of friction (or worse).
And since that's a brand new setup with the new rings, and piston and bore, the heat build up might be explained with normal heavy wear while the parts break-in.. Extra friction could also explain the high idle speed needed to keep it running, although it seems like there is way too much friction somewhere.
  Honda "Express"ing difficulty...Topic by: James Foster James Foster 02/25/05 11:22PM
  Re: Honda "Express"ing difficulty...Re: Dan Adams (50:1) Dan Adams (50:1) 02/25/05 11:39PM
  Re: Honda "Express"ing difficulty...Re: James Foster James Foster 02/25/05 11:57PM
  Re: Honda "Express"ing difficulty...Re: Joe Woods Joe Woods 02/26/05 12:18AM
  Re: Honda "Express"ing difficulty...Re: Jonas Quimby Jonas Quimby 02/26/05 08:17AM
  Re: Honda "Express"ing difficulty...Re: James Foster James Foster 02/26/05 12:41AM
  Re: Honda "Express"ing difficulty...Re: James Foster James Foster 02/26/05 10:44AM
  Re: Honda "Express"ing difficulty...Re: Jason Luther Jason Luther 02/26/05 04:58PM
  Re: Honda "Express"ing difficulty...Re: James Foster James Foster 02/26/05 05:36PM
  Re: Honda "Express"ing difficulty...Re: Joe Woods Joe Woods 02/26/05 05:46PM
  Re: Honda "Express"ing difficulty...Re: Jonas Quimby Jonas Quimby 02/26/05 09:32PM
  Re: Honda "Express"ing difficulty...Re: James Foster James Foster 02/26/05 08:53PM
  Re: Honda "Express"ing difficulty...Re: Joe Woods Joe Woods 02/26/05 09:42PM
  Re: Honda "Express"ing difficulty...Re: James Foster James Foster 02/26/05 11:10PM
  Re: Honda "Express"ing difficulty...Re: Joe Woods Joe Woods 02/26/05 11:55PM
  Re: Honda "Express"ing difficulty...Re: James Foster James Foster 02/27/05 12:39AM
  Re: Honda "Express"ing difficulty...Re: James Foster James Foster 02/27/05 08:05PM
  Re: Honda "Express"ing difficulty...Re: Joe Woods Joe Woods 02/27/05 08:57PM
  Re: Honda "Express"ing difficulty...Re: James Foster James Foster 02/27/05 10:29PM
  Re: Honda "Express"ing difficulty...Re: Jonas Quimby Jonas Quimby 02/28/05 04:52AM
  Re: Honda "Express"ing difficulty...Re: James Foster James Foster 02/28/05 10:44AM
  Re: Honda "Express"ing difficulty...Re: Joe Woods Joe Woods 02/28/05 07:01PM
  Re: Honda "Express"ing difficulty...Re: James Foster James Foster 02/28/05 08:44PM
  Re: Honda "Express"ing difficulty...Re: Joe Woods Joe Woods 02/28/05 09:02PM
  Re: Honda "Express"ing difficulty...Re: James Foster James Foster 02/28/05 11:03PM
  Re: Honda "Express"ing difficulty...Re: Joe Woods Joe Woods 02/28/05 11:21PM
  Re: Honda "Express"ing difficulty...Re: James Foster James Foster 02/28/05 11:40PM
