Puch turn signals...
Hi there!
Where I live, mopeds have to have flashers (turning signal lights) to be lisenced for the street... I happen to have stumbled on a potentially good deal for a 1978 Puch which doesn't have signal lights...
How easy it is to add this kind of feature to a moped and how should I expect to pay for it?
Thanks,
Buzz
Re: Puch turn signals...
if you can fing a set of cateye turn signals, it's very easy to hook them up...they run on a seperate battery.
Matthew Libhart /
Marc,
I'm planning on hooking up some signals to my '78 Puch. I'm hoping that my magneto will be able to drive them (it should, even though it's sort of a weird AC/DC mix). I purchased a small license plate frame that had the signals already on it on Ebay, this was meant for, of all things, a Harley. I also got a 3-way switch that looks almost identical to the one on my Puch now (that little chrome job w/the push lever on the side). Now I have to wait for all that to get here, and in the meantime I'm going to find a 6V flasher relay, which shouldn't be too hard. If you're interested in going this route vs the battery option, reply and I'll post some pics or something once I get them working.
there is one wire to solder so the yellow wire on the light switch
a VERY easy install
the only problem you might have is a bad battery
i had to buy 5 seperate sub-C batteries with solder tabs from zbattery.com as my old battery pack was bad
oh yea
i also had to replace the original switch with a new SPDT toggle switch
your lucky to find a kit
i searched for 1 year before finding one
check out my homemade welder @
www.moody.tvheaven.com
