Re: Air Filter HELP
E K /
You'll need a better carb for these. The original carbs on these 36cc sucks. You'll need to get a good high performance carb/jet then you probably would see an increase.
But before you do anything further, remove the air filter and velocity stack. Start the scooter. How does it run? If it runs fine... Then that's the problem. If it doesn't... Something else is wrong.
EK
