MoPedLar need ur help
hey i remember that you posted a place to get replacement Vbelts and even a size and model for my vespa ciao. Im almost done rebuiling it and deceided that a new belyt wouldnt hurt.
thanks again!
Ps you goin to the Virgina Rally? i may be
Re: MoPedLar need ur help
The OEM belt is a Mitsuboshi 23100-148-7030 available from Honda Dealers for $60.00
The OEM belt length measured on the top side (outside diameter) is 41 inches (104.14 centimeters)
The top and sides of the OEM belt (width) each measures 19/32 inch
The bottom width of the OEM belt measures 11/32 inch
Dayco #17415 (also has 13A055 stamped on it) will work for $12.00 (it is a 41.5" belt, slightly larger than stock
from lenny at MRA
See Ya Moped Army /
I haven't heard about the Richmond Rally. If I'm invited, I'll try to be there.
word thanks for the info....mopedlar, its on the front page
isnt that a belt for a PA50II? not for the vespa?
Yeah- email zippy for a belt- i think he said they are like 14 dollars or so- he has the exact belt for the ciao
zippymoped@yahoo.com
i use hardware store belts- i can't remember what size exactly i use, but i can check tonight and see if there are any numbers left to look at on my belt.
yeah matt, my bad. i messed up there........sorry about that.
sweet thanks jay, and paul...totally not a problem
"isnt that a belt for a PA50II? not for the vespa?"
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
That certainly may fit a PA50 II, but I'm pretty sure it also fits a Vespa Bravo - Not sure about the Ciao, though.
yea..i just checked, it htink its too large...i ordered a OEM belt from zippy tho ..n o biggie
