Tomos Oil pump installed wrong??
I just installed a 27 tooth sprocket on my 1999 Tomos Targa LX. I had to remove the oil pump and a thin washer and rubber seal and a metal conector to the magneto to the oil pump. I think i got the washer or the rubber seal or that connecter in a different order b/c it is making a larger noise than before I installed the sprocket. But I do know it is defiantly getting oil and is pumping. So could anyone help me please!
Re: Tomos Oil pump installed wrong??
The little connector thing I refered too is actual the clutch.
So I need help fast.
Don Pflueger /
THE WASHER GOES UNDER THE FLYWHEEL NUT.
Could you put that in more detail.
Don Pflueger /
more detail??????
how much more detailed can i be? the washer goes under the flywheel nut.
Don Pflueger /
ok. i may be wrong about the washer. there is one that goes in between the pump and the rubber piece.
So it goes in order oil pump, washer , then rubber seal.
Also that number 26 in the pic. does it have the flat side against the oil pump or the raised side??
Thanks again, Cory Mohr
Num. 25 i mean
Don Pflueger /
i'd say the raised side towards the pump
