IGNITION COIL
Michael Larson /
I was just wondering where and how to connect the ignition coil on my 92 tomos targa
Re: IGNITION COIL
Don Pflueger /
the coil mounts on the left hand side of the frame, just above the engine, below the side cover. you should have three wires coming out of the magneto. yellow, black, and blue. the blue will plug onto the pos terminal on the coil, and black will plug onto the negative side.
Re: IGNITION COIL
Michael Larson /
there is no blue wire
Re: IGNITION COIL
Michael Larson /
would you mind sending a link for a diagram because on there i only have the black brown and then a double brown wire thankyou
Re: IGNITION COIL
Don Pflueger /
brown, black, and double brown?????
if your bike has an a35 engine, here is a manual for it.
http://www.mopedriders.org/article_view.php?faq=2&fldAuto=21
but if you have the a3n, you need this manual.
http://www.mopedriders.org/article_view.php?faq=2&fldAuto=27
ive never seen a tomos engine with that wire combination. black yes, but never brown coming out of the magneto. all the a35's use black and yellow. the a3 and a3n's used black, yellow, and blue. at least on the ones ive seen.
Re: IGNITION COIL
connect the black wire from the magneto to the red wire on the coil, and ground the brown wire.
