Success!!
Brian Tam /
Success! It runs, kind of.....
Taking off the carb (for the 4th time this weekend) and soaking it in Mineral Spirits must have done the trick. Zippy, the reed valve was working, and was clean. I did go through the entire carb with a wire and make sure all the passages are clear. All the checks and the soak must have done it.
However, now it doesnt idle. And it only runs when I sit on the seat. I stand up on the pedals and it dies, then I sit down and it revs. This may be a wiring short, but is there a possibility there is a safety switch in the seat?? I havent yet had a chance to go through the wiring, and this may solve the problem.
Thanks for all the help in advance fellas.
