Re: Honda PA50II carb problems
Don Pflueger /
take the carb back off and run a piece of wire thru every hole you can find in its body and all its parts. make sure that when you put it back together that you have the bowl on the right way and the float moves correctly. also check compression. you want to see 120 lbs or higher. drop the exhaust and make sure the port is clean as well as the exhaust itself.
