I'm trying to put together a Sachs with a 505/1D engine. It wasn't put gether or running when I got it so I'm not sure about how the clutch cable is suppose to work
From what I can determine:
I hook the clutch cable inside the clutch mechanism, run it out through the leadhole in the side of the clutchbox, through the decompression valve....then what?
If I connect that cable directly to the brake lever, how will I engage the back brake? Or if I thread it through the cable lead that's on top of that bracket on the pedal arm that the back, I guess that will connect the back brake to the clutch but how do I then engage them(do I need an additional brake cable?).
Help!
