You like it better one you iron thing out...patience young grasshopper. With the removal bit procedure you will not have to remove the cylinder. Like I said...just have a friend hold the bike in a standing wheelie position so you can control your bits, it takes a steady hand. Use a point set to start the hole if you have to. Don't be afraid to ask the guy at the hardware store to explain how to use the removal bit.
