Re: Good God what happened? Tomos...hot wires=no s
Don Pflueger /
to test for power output you do not need to pull the flywheel. but to test ohms on each coil, you need to remove the flywheel, then remove the coils from the stator plate and test them individually.
Don Pflueger /
electrical parts can look fine but still be bad. and if you broke part of the coil you will need a new one.
No. it's just this tiny little plastic cap for the end of the wires. I'll try replacing the wire and see what that does first. If that doesn't do the trick then I'll try the other magneto.
