Re: same issues, but more irritating
Joe Woods /
Visual inspection says a lot.. If the condenser's can bulges out of there is any leakage, toss it. Meters that accurately diagnose capacitors are expensive. So the short easy answer is to substitute a known good condenser.
I've got a DMM (digital multimeter) that has a capacitor checker.. What it does is fully charge the condenser and then measure how much capacity it actually has.. Although this says the cap is not dead-shorted or has some major malfunction, this doesn't determine if the cap is leaking more than it should. (Charge in a condenser always leaks cross the plates but only at some acceptable rate in a good one..) Another thing is the meter can only charge the cap to a low voltage.. not the voltage is sees normally. Breakdown voltage is important. An oscilloscope to test a cap while it's in the circuit might be needed.
If you are suspect misfires, how about hooking up a inductive timing light .. the flashes of light would not be steady BUT the plug would not show a wet, fouled condition.
  same issues, but more irritatingTopic by: James Foster James Foster 01/26/05 07:28PM
  Re: same issues, but more irritatingRe: Paul P Paul P 01/26/05 08:25PM
  Re: same issues, but more irritatingRe: John Joedicke John Joedicke 01/26/05 08:41PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/26/05 08:42PM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 01/26/05 08:53PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/26/05 09:05PM
  Re: same issues, but more irritatingRe: Paul P Paul P 01/26/05 09:51PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/26/05 09:55PM
  Re: same issues, but more irritatingRe: Tony Daniel Tony Daniel 01/27/05 02:05AM
  Re: same issues, but more irritatingRe: Joe Woods Joe Woods 01/27/05 03:31AM
  Re: same issues, but more irritatingRe: Tony Daniel Tony Daniel 01/27/05 11:24AM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 01/29/05 08:23PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/27/05 10:13AM
  Re: same issues, but more irritatingRe: Tony Daniel Tony Daniel 01/27/05 11:21AM
  Re: same issues, but more irritatingRe: Joe Woods Joe Woods 01/27/05 12:48PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/27/05 01:33PM
  Re: same issues, but more irritatingRe: Tony Daniel Tony Daniel 01/27/05 03:01PM
  Re: same issues, but more irritatingRe: Richard Wisniewski Richard Wisniewski 01/30/05 11:37AM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/27/05 04:14PM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 01/27/05 06:49PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/27/05 07:16PM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 01/27/05 09:41PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/27/05 10:28PM
  Re: same issues, but more irritatingRe: Joe Woods Joe Woods 01/27/05 11:16PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/28/05 12:08AM
  Re: same issues, but more irritatingRe: Joe Woods Joe Woods 01/28/05 12:34AM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/28/05 01:14AM
  Re: same issues, but more irritatingRe: Tony Daniel Tony Daniel 01/28/05 01:31AM
  Re: same issues, but more irritatingRe: Joe Woods Joe Woods 01/28/05 01:32AM
  Re: same issues, but more irritatingRe: Tony Daniel Tony Daniel 01/28/05 01:43AM
  Re: same issues, but more irritatingRe: E K E K 01/28/05 03:45AM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/28/05 10:55AM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/30/05 01:34AM
  Re: same issues, but more irritatingRe: Richard Wisniewski Richard Wisniewski 01/30/05 11:32AM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/30/05 01:43PM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 02/03/05 09:06PM
  Re: same issues, but more irritatingRe: James Foster James Foster 02/04/05 12:16AM
  Re: same issues, but more irritatingRe: Ben Van Zoest Ben Van Zoest 02/04/05 02:37AM
  Re: same issues, but more irritatingRe: James Foster James Foster 02/04/05 10:08AM
  Re: same issues, but more irritatingRe: James Foster James Foster 02/05/05 05:43PM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 02/05/05 06:21PM
  Re: same issues, but more irritatingRe: James Foster James Foster 02/05/05 06:40PM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 02/05/05 06:57PM
  Re: same issues, but more irritatingRe: James Foster James Foster 02/05/05 09:32PM
