Re: same issues, but more irritating
James Foster /
Yea, I see what you mean Joe. It's probably something so simple that I didn't even bother to look at it. The last modification I did was to swap both the 15mm intake and carb for 14mm ones. Reason being that they were cheaply made by some weird company other than "bing", and both have something broken on them. Intake; had a crack next to one of the bolt holes and in the process of removing it, it broke off. Upper throttle body on the carb; had a small crack on one of the little metal pieces that holds the float's needle in place, then it broke off. So, I had to switch back to my original carb for now.
The problem is, I've tried a 72, 76, 78, and a 82 size bing jet in the 14mm bing carb already. But even with adjusting the air intake, it won't run right. If I restrict the air too much, it has horrible top end, and if I don't restrict it enough, then it usually dies. This was tried with every jet I own, but nothing seems to work right, like there's something else at fault. Whats irritating is that I'd taken apart the crankcase awhile back, but everything looked fine. I've tried every major trick that I can find/think of, but nothing seems to work. Even if there were like a dozen of the best moped people I know looking at my bike right now, even they might be stumped. I just don't know what to do. :(
Still pondering,
JF
  same issues, but more irritatingTopic by: James Foster James Foster 01/26/05 07:28PM
  Re: same issues, but more irritatingRe: Paul P Paul P 01/26/05 08:25PM
  Re: same issues, but more irritatingRe: John Joedicke John Joedicke 01/26/05 08:41PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/26/05 08:42PM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 01/26/05 08:53PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/26/05 09:05PM
  Re: same issues, but more irritatingRe: Paul P Paul P 01/26/05 09:51PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/26/05 09:55PM
  Re: same issues, but more irritatingRe: Tony Daniel Tony Daniel 01/27/05 02:05AM
  Re: same issues, but more irritatingRe: Joe Woods Joe Woods 01/27/05 03:31AM
  Re: same issues, but more irritatingRe: Tony Daniel Tony Daniel 01/27/05 11:24AM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 01/29/05 08:23PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/27/05 10:13AM
  Re: same issues, but more irritatingRe: Tony Daniel Tony Daniel 01/27/05 11:21AM
  Re: same issues, but more irritatingRe: Joe Woods Joe Woods 01/27/05 12:48PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/27/05 01:33PM
  Re: same issues, but more irritatingRe: Tony Daniel Tony Daniel 01/27/05 03:01PM
  Re: same issues, but more irritatingRe: Richard Wisniewski Richard Wisniewski 01/30/05 11:37AM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/27/05 04:14PM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 01/27/05 06:49PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/27/05 07:16PM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 01/27/05 09:41PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/27/05 10:28PM
  Re: same issues, but more irritatingRe: Joe Woods Joe Woods 01/27/05 11:16PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/28/05 12:08AM
  Re: same issues, but more irritatingRe: Joe Woods Joe Woods 01/28/05 12:34AM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/28/05 01:14AM
  Re: same issues, but more irritatingRe: Tony Daniel Tony Daniel 01/28/05 01:31AM
  Re: same issues, but more irritatingRe: Joe Woods Joe Woods 01/28/05 01:32AM
  Re: same issues, but more irritatingRe: Tony Daniel Tony Daniel 01/28/05 01:43AM
  Re: same issues, but more irritatingRe: E K E K 01/28/05 03:45AM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/28/05 10:55AM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/30/05 01:34AM
  Re: same issues, but more irritatingRe: Richard Wisniewski Richard Wisniewski 01/30/05 11:32AM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/30/05 01:43PM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 02/03/05 09:06PM
  Re: same issues, but more irritatingRe: James Foster James Foster 02/04/05 12:16AM
  Re: same issues, but more irritatingRe: Ben Van Zoest Ben Van Zoest 02/04/05 02:37AM
  Re: same issues, but more irritatingRe: James Foster James Foster 02/04/05 10:08AM
  Re: same issues, but more irritatingRe: James Foster James Foster 02/05/05 05:43PM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 02/05/05 06:21PM
  Re: same issues, but more irritatingRe: James Foster James Foster 02/05/05 06:40PM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 02/05/05 06:57PM
  Re: same issues, but more irritatingRe: James Foster James Foster 02/05/05 09:32PM
