Re: same issues, but more irritating
Tony Daniel /
If you have a Bing Carb I would try adjusting the needle jet. To get to it, take the top of the carb off. remove the throttle slide and you will see a tapered pin coming out the bottom. This is the needle jet.
It has four adjustments at the top. You will see a clip on it in one of the four grooves. If the clip is near the top groove it is set where the tapered needle will allow a lean mixture during low speeds. If you drop the clip to the bottom groove it will raise the needlejet and make a richer mixture.
The symptom you describe is a bog and is caused when the air does not get enough fuel mixed with it. When you are idling, the throttle slide is closed and very little air passes through the Ventura area of the carb.. When you open the throttle your engine sucks a greater amount of air. This requires a rush of fuel to atomize with it. Raising the needle will allow that extra fuel at the initial opening of the slide.
  same issues, but more irritatingTopic by: James Foster James Foster 01/26/05 07:28PM
  Re: same issues, but more irritatingRe: Paul P Paul P 01/26/05 08:25PM
  Re: same issues, but more irritatingRe: John Joedicke John Joedicke 01/26/05 08:41PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/26/05 08:42PM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 01/26/05 08:53PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/26/05 09:05PM
  Re: same issues, but more irritatingRe: Paul P Paul P 01/26/05 09:51PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/26/05 09:55PM
  Re: same issues, but more irritatingRe: Tony Daniel Tony Daniel 01/27/05 02:05AM
  Re: same issues, but more irritatingRe: Joe Woods Joe Woods 01/27/05 03:31AM
  Re: same issues, but more irritatingRe: Tony Daniel Tony Daniel 01/27/05 11:24AM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 01/29/05 08:23PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/27/05 10:13AM
  Re: same issues, but more irritatingRe: Tony Daniel Tony Daniel 01/27/05 11:21AM
  Re: same issues, but more irritatingRe: Joe Woods Joe Woods 01/27/05 12:48PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/27/05 01:33PM
  Re: same issues, but more irritatingRe: Tony Daniel Tony Daniel 01/27/05 03:01PM
  Re: same issues, but more irritatingRe: Richard Wisniewski Richard Wisniewski 01/30/05 11:37AM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/27/05 04:14PM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 01/27/05 06:49PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/27/05 07:16PM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 01/27/05 09:41PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/27/05 10:28PM
  Re: same issues, but more irritatingRe: Joe Woods Joe Woods 01/27/05 11:16PM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/28/05 12:08AM
  Re: same issues, but more irritatingRe: Joe Woods Joe Woods 01/28/05 12:34AM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/28/05 01:14AM
  Re: same issues, but more irritatingRe: Tony Daniel Tony Daniel 01/28/05 01:31AM
  Re: same issues, but more irritatingRe: Joe Woods Joe Woods 01/28/05 01:32AM
  Re: same issues, but more irritatingRe: Tony Daniel Tony Daniel 01/28/05 01:43AM
  Re: same issues, but more irritatingRe: E K E K 01/28/05 03:45AM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/28/05 10:55AM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/30/05 01:34AM
  Re: same issues, but more irritatingRe: Richard Wisniewski Richard Wisniewski 01/30/05 11:32AM
  Re: same issues, but more irritatingRe: James Foster James Foster 01/30/05 01:43PM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 02/03/05 09:06PM
  Re: same issues, but more irritatingRe: James Foster James Foster 02/04/05 12:16AM
  Re: same issues, but more irritatingRe: Ben Van Zoest Ben Van Zoest 02/04/05 02:37AM
  Re: same issues, but more irritatingRe: James Foster James Foster 02/04/05 10:08AM
  Re: same issues, but more irritatingRe: James Foster James Foster 02/05/05 05:43PM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 02/05/05 06:21PM
  Re: same issues, but more irritatingRe: James Foster James Foster 02/05/05 06:40PM
  Re: same issues, but more irritatingRe: Jason Luther Jason Luther 02/05/05 06:57PM
  Re: same issues, but more irritatingRe: James Foster James Foster 02/05/05 09:32PM
