hot wire???
Jeremy Schaefer /
i have a 1980 puch maxi 2 hp 6 wire motor...is the blue wire coming from the stator the hot wire??? must all brown wires be grounded??? thanks--Jeremy
Re: hot wire???
Jeremy Schaefer /
by the way...if i connect the hot wire from my stator to the blue wire that goes to the coil, and the coil is grounded, even w/o a kill switch wired up...should i get spark?
this wiring thing is startin to bug me!!
Re: hot wire???
Jason Luther /
i think the blue was for the tail brake lights. the black is the spark wire. and yes, if you hook the black to the coil wire (blue) and then ground the coil, you should get spark. all the kill switch does is interupt the ground. i would double check with the wiring diagram from mopedriders.org. -jason
Re: hot wire???
Jason Luther /
scratch that. yes the blue is the spark wire. the blue/black is the brake light.
