1977 maxi sport wiring diagram
Jeremy Schaefer /
im officially facing my fears...im redoing the wiring completely
in my motor swap...i swapped a good running 1980 6 wire system for a junk '77 1hp...the 2 is going on my '77 maxi sport. the motor is from an '80 luxe. I need your help...the wiring has been a big pain in the @$$ to successfully swap. DOES ANYONE KNOW WHERE I CAN FIND AN ACCURATE WIRING DIAGRAM FOR A '77 SPORT??? there is a good 1980 on mopedsonline.com, but a sketchy '77 i just dont get. does anyone know where to find a GOOD one online??? thanks so much--Jeremy
p.s. the 77 was made for a 5 wire system that kills the motor if a light burns out...the 80 is 6 wire and wont quit if lights die... thanks again.
Re: 1977 maxi sport wiring diagram
Jeremy Schaefer /
I found a good one!!!
