Re: commuter 1980 moped
Tony Daniel /
I don,t have a Commuter ped but the Puch has the black lever also, operates the starting clutch. It is slightly loose from wear but Mine doesn't need fixing yet.
Looking at mine it is held in by a roll pin, If I were to fix it I would knock out the roll pin, then measure its diameter. I would then find a brass insert that was 1mm larger and drill the hole for the size of the pin. I would then get a drill that size and drill out the hole in the handle. Lube the insert with grease, put the insert in the handle, put the handle in place and drive in the roll pin.
  commuter 1980 mopedTopic by: August Anton August Anton 01/25/05 11:00PM
  Re: commuter 1980 mopedRe: Joe Woods Joe Woods 01/25/05 11:30PM
  Re: commuter 1980 mopedRe: E K E K 01/26/05 05:52AM
  Re: commuter 1980 mopedRe: Jake Van Order Jake Van Order 01/30/05 04:59AM
  Re: commuter 1980 mopedRe: Steamboat Aka J. R. Stevens Steamboat Aka J. R. Stevens 01/30/05 10:25AM
  Re: commuter 1980 mopedRe: E K E K 01/30/05 09:24PM
  Re: commuter 1980 mopedRe: Steamboat Aka J. R. Stevens Steamboat Aka J. R. Stevens 01/31/05 09:38AM
  Re: commuter 1980 mopedRe: E K E K 01/31/05 02:34PM
  Re: commuter 1980 mopedRe: E K E K 01/30/05 09:25PM
  Re: commuter 1980 mopedRe: Tony Daniel Tony Daniel 01/31/05 10:14AM
  Re: commuter 1980 mopedRe: Tony Daniel Tony Daniel 01/31/05 10:22AM
  Re: commuter 1980 mopedRe: E K E K 01/31/05 02:41PM
  Re: commuter 1980 mopedRe: E K E K 01/31/05 02:36PM
  Re: commuter 1980 mopedRe: Dan Adams (50:1) Dan Adams (50:1) 01/30/05 04:08PM
  Re: commuter 1980 mopedRe: Tony Daniel Tony Daniel 01/30/05 05:44PM
  Re: commuter 1980 mopedRe: E K E K 01/30/05 09:21PM
  Re: commuter 1980 mopedRe: Steamboat Aka J. R. Stevens Steamboat Aka J. R. Stevens 01/31/05 03:28PM
  Re: commuter 1980 mopedRe: E K E K 01/31/05 04:55PM
  Re: commuter 1980 mopedRe: E K E K 01/31/05 05:02PM
  Re: commuter 1980 mopedRe: Steamboat Aka J. R. Stevens Steamboat Aka J. R. Stevens 01/31/05 06:52PM
  Re: commuter 1980 mopedRe: E K E K 01/31/05 09:16PM
  Re: commuter 1980 mopedRe: E K E K 01/31/05 09:17PM
  Re: commuter 1980 mopedRe: E K E K 02/01/05 01:09AM
  Re: commuter 1980 mopedRe: E K E K 02/01/05 01:35AM
