Re: commuter 1980 moped
Joe Woods /
I mix fuel/oil in a large glass apple juice bottle that holds about 1/2 gallon using a funnel..
I put a strip of masking tape up the side and poured in measured amounts of water to accurately marked the tape for 1/2 quart, 1 quart, 1-1/2 quarts,etc.. Find a small plastic measuring cup for the oil.
For example, I use a 32:1 mixture. Add an ounce of oil to the measuring cup and then pour a bit of gasoline in that cup and swish it around to mix it.. Then pour that into the jar. Then fill the jar with gasoline to the 1 quart mark and swish it around again.
(One ounce per quart is 4 ounces per gallon.. and that would give you a 32:1 oil mix ratio. )
Oil must be well mixed into the gasoline. Premix it well before pouring in the tank.
And everyone will tell you DO NOT use glass containers for gaoline since if it hits the concrete and breaks you might start a fire from the fumes before you can swab it all up.. If you have a plastic see-through container, it is infinately preferable to using a glass jar or bottle.
  commuter 1980 mopedTopic by: August Anton August Anton 01/25/05 11:00PM
  Re: commuter 1980 mopedRe: Joe Woods Joe Woods 01/25/05 11:30PM
  Re: commuter 1980 mopedRe: E K E K 01/26/05 05:52AM
  Re: commuter 1980 mopedRe: Jake Van Order Jake Van Order 01/30/05 04:59AM
  Re: commuter 1980 mopedRe: Steamboat Aka J. R. Stevens Steamboat Aka J. R. Stevens 01/30/05 10:25AM
  Re: commuter 1980 mopedRe: E K E K 01/30/05 09:24PM
  Re: commuter 1980 mopedRe: Steamboat Aka J. R. Stevens Steamboat Aka J. R. Stevens 01/31/05 09:38AM
  Re: commuter 1980 mopedRe: E K E K 01/31/05 02:34PM
  Re: commuter 1980 mopedRe: E K E K 01/30/05 09:25PM
  Re: commuter 1980 mopedRe: Tony Daniel Tony Daniel 01/31/05 10:14AM
  Re: commuter 1980 mopedRe: Tony Daniel Tony Daniel 01/31/05 10:22AM
  Re: commuter 1980 mopedRe: E K E K 01/31/05 02:41PM
  Re: commuter 1980 mopedRe: E K E K 01/31/05 02:36PM
  Re: commuter 1980 mopedRe: Dan Adams (50:1) Dan Adams (50:1) 01/30/05 04:08PM
  Re: commuter 1980 mopedRe: Tony Daniel Tony Daniel 01/30/05 05:44PM
  Re: commuter 1980 mopedRe: E K E K 01/30/05 09:21PM
  Re: commuter 1980 mopedRe: Steamboat Aka J. R. Stevens Steamboat Aka J. R. Stevens 01/31/05 03:28PM
  Re: commuter 1980 mopedRe: E K E K 01/31/05 04:55PM
  Re: commuter 1980 mopedRe: E K E K 01/31/05 05:02PM
  Re: commuter 1980 mopedRe: Steamboat Aka J. R. Stevens Steamboat Aka J. R. Stevens 01/31/05 06:52PM
  Re: commuter 1980 mopedRe: E K E K 01/31/05 09:16PM
  Re: commuter 1980 mopedRe: E K E K 01/31/05 09:17PM
  Re: commuter 1980 mopedRe: E K E K 02/01/05 01:09AM
  Re: commuter 1980 mopedRe: E K E K 02/01/05 01:35AM
