vespa SI parts
Justin Brownell /
Are vespa SI parts hard to find?
I've been offered one needs new wiring. I was wondering if I should consider it. thanks
Justin
Re: vespa SI parts
The wiring is all there, it just needs to be connected in the right order. I have the diagram, but haven't had the time. (I don't know if you replied to my e-mail, I can't check it from work, which is where I'm at right now and I don't have internet at home.) I'll check it tonight.
Re: vespa SI parts
All Vespas all use the same engine, carb and pretty much everything else is interchangable. The only exception is slightly different wheels.
Re: vespa SI parts
and suspention and sometimes triple trees in the front or a single mast.
hey where is this SI located ne way?'
Re: vespa SI parts
In my shop.
