Re: coil for minarelli
Don Pflueger /
jasons right. no sense in buying a $60 coil if its not bad. usually dirty or misadjusted points is the problem, or a bad condensor. the only time coils really go bad is when they are broken open, or have had excessive voltage applied to them. there are two types of coils. single terminals which ground thru the frame. and double terminals which ground thru a negative lead wire. there is a minerelli service manual at www.mopedriders.org in the repair area which will help you to test the individual parts to see whats bad or not.
