Re: sucked/broken reed = bad
Don Pflueger /
all it would do is fall into the crankcase which is sealed off from the transmission. you wont need to split the engine cases, just pull the cylinder off and fish the reed out. hopefully it didnt damage the piston skirts or the crankshaft. but it sounds like you may be ok cuz the engine turns over freely. just pull the cylinder off and fish it out.
