Re: Piston tool
Joe Woods /
It's not easy and some are harder .. The hard part is holding the ring closed while holding the cylinder and at the same time slipping the piston into the cylinder. If you accidentally turn the piston a little and the ring expands slightly and a ring's end catches in a port or on some sharp edge.. and you push.. and you got a snapped ring.
Use some sort of a band around the ring so you can concentrate on the other stuff.
