Batavus Engine Question
What type of engine is on a Starflite Top tank? And did they make different speed versions?
Thanks,
Fred
Re: Batavus Engine Question
Don Pflueger /
either a laura m48 or a laura m56 and they came in 20, 25, and 30 mph versions.
Do you know what the markings are on the engine? How do you tell the difference between the engine types? I do not know much about them as I have never worked on one.
Thanks,
Fred
Don Pflueger /
the different speeds are determined by carb and intake size and jetting.
Sounds good! Thanks for the help. I was just unsure if the restricted in the cylinder like the Sachs engines!
Thanks!
Fred
Correction, slow model Sachs aren't truly restricted in the cylinder, but in the carburator and exhaust.. Sachs are much easier to derestrict than a Batavus.
Is this true? My Sparta has an a3 cylinder and has the bigger bing and a less restricted pipe I picked up at the BBQ but still only goes about 25mph...
I see they have larger cylinder at the junk yard...but too much for my wallet.
