noob question
Martin Olkowicz /
allright, im probably going to get eaten alive for this question, but bear with me, ive only had tomas sprint's for a few weeks we have 6 of them between 3 friends anyway. i need to know how do i change the tranny oil, i dont see a fill or drain plug, am im just completely missing it? thanks in advance!! ( the ones that im concerned with are the 94, 99, 97, and 93 sprints)
Re: noob question
alright there is a nut on the bottom. remove that a drain the fluid. then remove the top screw (under the airbox) and side screw. replace the bottom screw and fill it with tranny fluid until it comes out the side screw on the case.
then replace the top and side screw and your ready to go.
make sure it's on a level surface, and if you have a sidestand to stand the bike upright when topping it off.
noob question
There are a couple of Tomos Manuals here:
http://www.mopedriders.org/article_cat.php?fldAuto=2
I am not sure if they will help with your immediate problem, but they might be of some help in the future.
Re: noob question
Martin Olkowicz /
thanks alot guys, once it stops snowing, im going to go change my oil
