Re: E-ton Beamer junk
Joe Woods /
i assume this is a fairly new bike.
you could blame the starting, bogging and intermittant no-run situation on an ignition problem. Maybe some bolt or screw has loosened and some ignition-related electrical contact is poor or has now failed completely.
Another possibility is some other bolts, like the head bolts or intake manifold are loosening.. air or vacuum leaks can do it.
