Tomos A-3
Jeff Strahle /
I have a 1991 Tomos Golden Bullet TTLX. A gear was stripped out, and i just got the gear from mopedjunkyard.com, but before i reinstall everything i want to know if there is a gasket that goes on the right hand side transmission cover. There is a gasket on the left hand side but that is where the crankshaft and piston and everything are so i would assume that would have to be kept airtight. any help is greatly appreciated.
Thanks
Jeff
Re: Tomos A-3
yes there are 2 gasekts, one for the crankshaft, and then an outer gasket for the transmission cover to hold the fluid in. i used gasket maker before. seems to work fine.
