Motobecane Coil
How do test the coil on a 1980 Motobecane 50V? The moped won't start:
Changed the spark plug
Check the points
thanks for your help!
Re: Motobecane Coil
See Ya Moped Army /
Make sure the taillight bulbs are there and not burned out or it will not start.
Re: Motobecane Coil
The moped will not spark? or just will not run?
If it will not spark also try this
Trim a half inch off the spark plug cable, and then make sure the piece that sticks into the coil is stuck well. There is a white wire conector near the engine that I think should be replaced with a terminal strip, cut and restrip all wires going there. inspect the kill switch on the left handle bar, these have a little spring, and bb's inside, and on more than one occation I have seen it get messed up, making the switch not work (horn always blowing, or moped always in not run mode)
Re: Motobecane Coil
this is what I mean by terminal strip http://www.allelectronics.com/cgi-bin/category.cgi?category=755&item=TB-7&type=store cut it in pieces, one terminal strip can do 3 mopeds
