WHEELS
Will older wheels from the Tomos Silver Bullett (1984) fit on newer Tomos Targa Lx (2003)???
Re: WHEELS
Don Pflueger /
they should.
Re: WHEELS
See Ya Moped Army /
You may run into problems with the hubs mounting differently in the rear.
Re: WHEELS
Don Pflueger /
you know what? i was thinking about this too. the front may not work because the silver bullet uses an upside down type of fork. they have different mounts than the newer models.
Re: WHEELS
well they may work. but the older wheels had loose ball bearings so they can be a pain sometime.
Re: WHEELS
Don Pflueger /
no they wont. whether they have loose or caged bearings makes no difference. what makes the differences are the hub widths, the spacers, the 13mm axle on the silver bullet versus the 14mm axle on the lx, and the brake setup. i have an 84 s.b. , an 87 g.b., and a 2000 lx. there are quite a bit of differences in them all.
Re: WHEELS
Jake Stover /
Thank you to all who helped me
