puch
i have a problem with my puch. i ride for about an hour then it starts to die but then goes, and does it repeatedly, also i chnge the spark plug 3 timmes and after every ride it turns black and oily. Please help!
Re: puch
if it runs ok for an hour there's probably nothing wrong.. maybe your choke is accidentally , partially closing for some reason.. This would make the engine run rich and die and foul the plug like you describe.
Check your carburetor / choke cables and see if something is not quite right.
Re: puch
you runnin a bit rich, maybe your airflow is being hampered in some way.... do as joew says
Re: puch
what oil/gas mixture are you running??
as mentioned, check that your choke is not sticking open.
Re: puch
Jason Luther /
does it run tip-top right off the bat?-jason
Re: puch
i found the problem i was running the weong fuel ratio! I am an idiot.
Re: puch
rofl...
Re: puch
Jason Luther /
always start with the simplest solutions
Re: puch
my puch is doing the same thing again. could it be a dirty carb?
Re: puch
clean carb, perform a plug chop. what mixture are you running???
Re: puch
Jason Luther /
i wouldnt think its a dirty carb. does it run /start fine and then die after a while? does it sputter and die after sitting at a light for a few minutes? try putting the needle in the carb slide on the upper most notch, leaning out the carb. and check your timing.-jason
