Re: head gaskets and compression
Joe Woods /
yeah.. i realized the bottom end could be the same a minute after i said it had to be different. I pictured a shorter stroke , bigger bore and higher RPM for some strange reason..
As far swapping pistons to get different port timing, it does sound like a really easy way to radically change the power curve but i wonder what you'd end up with ..
