Re: head gaskets and compression
Brett Walker /
i am not using any head gasket, just 1 base gasket, and i have about 140 psi, on my single speed puch,
the only damage that might happen instantly is if your piston hits the plug, however some people have told me about it causing the engine to over heat and so forth, but i have never had any real problems, however my compression was higher, almost 150, i think my rings are getting really worn, or my base gasket needs to be replaced
