where's it leaking from?
I have a 1996 Tomos Targa LX with an A 35 motor. I noticed some type of oil leaking on the floor just below the primary sprocket. Is there a main seal or smething there? How much of a problem is it to fix this? Thanks for any help.
Re: where's it leaking from?
See Ya Moped Army /
The pedal crank seal is most likely leaking. It's relatively easy to replace. If the seal looks pretty good after removing it, coat the outer edge of the seal with some Permatex before replacing it. It stopped the leak on my Targa.
