carb-intake
William Grandy /
I have a 1977 batavus starflite II and my carb is lose on the intake ive thighened it as much as possible and it still is lose what can i do i know its got to be letting air and affecteing the way it runs
Re: carb-intake
If you can figure out a way to file down some of the material in the clamp gap (thin file) that might work. Or put some kind of gas resistant sleeve over the intake then slide the carb over that. I try to pry the carb clamp open just enough to slip a file in there so the clamping bolt can go tighter.
