How to make the chain on my Tomos alittle longer?
Since I put the 27 sprokit on my Targa the axle bolt is not setted all the way back in it's place. It's forward about 1/2 inch with the chain tight. Does this matter? Should, and can, I make the chain longer?
Re: How to make the chain on my Tomos alittle long
Don Pflueger /
as long as the wheel will give slack in the chain when you back the adjuster off, you should be fine. the only way to lengthen a chain is to add a link, or a half link. and that requires a chain tool to do so.
Coo!
