Spark Plug trivia 101.........
So today, I finally joined the ranks of the winter moped rider, awsome time. I have a 1980 MOTOBECANE and she fired up no problem after sitting for 3 months (college). After crusing for around 4 hours, my ped started to loose all power at full throttle, at 1/2 my power was fine.
So, I pulled over, ripped out the autolite 425 spark plug, and noticed all around the gap, specks of like carbon that were fused onto the electrode. The white ceramic around the center electrode looks like it has brown mold.
Any ideas on why my spark plug has a fungus of sorts lol, thanks
boomhaur16
Re: Spark Plug trivia 101.........
Steamboat Aka J. R. Stevens /
Install new plug and see what happens. No harm done.
Jason Luther /
try cleaning your carb. you probably sucked some crap.-jason
Iiiiiiiii Died /
u may want to clean your tank out bccus if u sucked something in thru the gas theres the source did the spark plug get wet and form like mildew?
"Install new plug and see what happens. No harm done."
Bingo!!
well.. first off ditch the autolite and spin in a new NGK,
dump the old gas and get some fresh stuff in the tank
you know, give it a good once over
Try the next hotter range plug. The plug should be hot enough to burn off all deposits. This "fix" assumes that your fuel mixture and oil ratio and timing and everything else are OK.
