Re: 15mm amal carb problem i think. this sucks
Jason Luther /
you are able to put a million times more force with the tip of your little finger on the flaot to make the needle seal, so thats not a good test. try a different float needle if you have one laying around. and/or remove the float and put it in a cup of gas and see if it floats. its something simple, just throughly find out what. -jason
