runs good then dies after a while of riding
i'll be going along just fine, for about 10-20 minutes of riding but if i start to let off the gas even a little it will die and the only way i can get it started again is let it sit for a while. If i try to start it right back up it will pop once after i stop pedaling but sometimes i can pull the clutch alot of times very quick while pedaling and it will run.
so i was wondering if it could need a new spark plug or if it was getting flooded or what?
Re: runs good then dies after a while of riding
check your timing, that's what it sounds like.
Don Pflueger /
clean your gas cap vent.
Ben Van Zoest /
You got a serious fuel flow problem, make sure all carburator orifices are clear, important in near freezing conditions.
sounds like you either have a fuel problem in the line or petcock, or you have a bad coil that will stop running after it's hot. maybe even a condensor.
Steamboat Aka J. R. Stevens /
First, pull the plug wire and check for spark.
