Re: lights, voltage?
Steamboat Aka J. R. Stevens /
Pull a coouple of bulbs from your ped. The voltage is written on the bulb. You should replace with same bulb type. the alternator/generator is designed to put out a certain number of watts.The sum total wattage of all your bulbs and ignition should not exceed the out put wattage.
