Re: qt50 electrics
Joe Woods /
To make that a bit more clear:
When you turn the ignition switch ON or OFF, two wires connect and at the same time two other wires are disconnected.
The two that connect when you turn the ignition switch ON allow the engine to run. At the same moment, two wires that would normally kill the engine are now disconnected.
