WON"T IDLE
I'v unclogged my carb, but i still have to spray gas into the jet to get it to start, once it starts i can keep it to run, but i have to keep giving it gas. If i let off the throttle it cuts right out. My choke is messed up, but i don't know if its stuck on. If it is will this be keeping it from idling?
Re: WON"T IDLE
See Ya Moped Army /
Yes. If the choke is stuck, it will flood out your motor and keep it from idling.
Re: WON"T IDLE
Don Pflueger /
or you have a leaking base gasket or crankseal.
Re: WON"T IDLE
Have you tried to adjust your carb yet? get the bike running and try adjusting the idle screw, see if it helps. also did you completely clean your carb? every passageway needs to be clean
Re: WON"T IDLE
Chad Watkins /
Yes it only has one adjustment(idle) and it's too hard to adjust with the choke always on...I'm going to take it to the shop Tuesday and have them fix the choke. Its one weird choking system.
