carb changes
Sean Reisdorf /
I hope some of you ventren ped owners can help.
I have a 1978 Puch/Sears Free Spirit.
The bike came with 1/14/xxx carb
I've found some parts I needed, but others are hard to find.
Therefore I've started looking for new/used carbs on eBay and other sites like this one.
The problem is that most of the carbs are 15mm or 12mm
Therefore, what will I have to do to modify these carbs to fit my ped.
I'm "assuming" that the difference in the carb sizes comes from the intake size.
Therefore, if I bolt a 15mm carb on my bike that uses a 14mm will I have to step down the metting jet and/or adjust the float level?
Please cc any replies directly to my work address... sreisdor@ford.com
Thanks in advance!
Sean
